Please help, Going crazy, Brake pads too thick - SOLVED
mmbow702
Redoing brakes and rotors on my 02' Tahoe LS. My caliper WONT fit over the new rotor and brake pads. Dual piston caliper, and got the supposed right parts for the job. What am I missing here?
M
mmbow702
First I tried some cheap Amazon bs, but once that failed I went with Autozone 55067DL for the rotor and MKD792 pads.
M
mmbow702
I lied, brake pads were MKD834
M
mmbow702
What parts (brand, part #) are you using for this brake job?
Stumbled across an old post where you helped someone out. Something about Akebono caliper stamped E4527 A50A50? This is the bs on my tahoe. I'm going to assume it's not stock, and possibly why nothing is fitting
nonickatall
Germany
It's very simple. If the pistons of your brake calliper are pushed all the way back and don't fit the new brake pads and rotors, then the brake pads and rotors are too thick.
I don't know how it is with our cars, but I know from many German cars that, depending on the engine installed or the year of manufacture, some have rotors that have a different diameter or thickness. So try to find out the standard thickness of the brake pad and disc on our vehicles and then measure how thick yours are.
Surely someone here in the forum knows how thick our standard brake pads and discs are?
C4fore
