Chump9
Just purchased a 2022 Z71 Tahoe. Put 295/60R20 tires on it (34.5”) and a 3” ready lift. It has completely destroyed our MPG. Around 12.5 mpg. I’m getting better mileage in my Ram 1500 with 35’s and a 6” lift. Does anybody have any suggestions on how to help? Looking at potentially putting a chip/programmer on the Tahoe to help. We need to get back up to around 15-16 mpg.
Thanks!
Welcome to the Forum from NH.
Pics of the truck, please.
I'm thinking that the heavier tires and the increased air resistance due to the lift may be negatively impacting your gas mileage. I doubt that any installed devices will significantly improve your gas mileage. Unfortunately, the most effective method to increase gas mileage is to better manage your foot on the gas pedal.
jfoj
Not many "mods" are going to drastically improve fuel economy.
12.5 MPG seems quite low. What engine does your truck have?
City/State you live in?
How much city/stop and go are you in?
Do you remote start and allow the truck to warm up?
Have you confirmed the operating temperature is typically around 205F? If the thermostat is soft and the engine is running cool, your fuel economy will suffer drastically.
Keep in mind when the engine is idling and the truck is not in motion, it gets EXACTLY 0 MPG which is then averaged into any distance the truck travels.
When on the highway what is your typical speed?
Bring up the MPG Average dash display and set it to 50 Mile Average and watch the instantanous MPG you are typically getting.
Take a picture of the dash after 50 miles and post it for reference.
DuraYuk
The mod was to get the lm2/lz0
The gasser is gonna burn gas with those tires and weight
Thanks!
Is this mileage revelation after several tanks of gas or just looking at the DIC for a few minutes???
What did you expect by adding all this weight and drag to your truck???
buckwild27
Aside from the added weight and wind drag. Cold weather affects mileage as well, if you live in a cold weather state. i average about 16.5 mpg in the summer months and 14.5 to 15 mpg in the winter without idling time.
ZKWBQD
Thanks!
Disable engine Stop-Start will improve gas mileage. There's a couple of kits to do this. I like the one that goes behind the dash.
Bigburb3500
What is the gearing and have you manually calculated the MPG? I’m wondering if the bigger tires has messed with the final drive ratios causing and drop in mileage or… someone else can correct me, if the computer hasn’t been changed to account for the larger diameter tires, the truck is getting confused on distance traveled and fuel being used.
jfoj
Would love to understand the science behind your statement. Understand that while the engine is running and the vehicle is not moving, your fuel ecomony will be EXACTLY 0 MPG. Averaging this into your economy per full tank of fuel, it can add up. We can debate all day long how much fuel may be saved, there will be a savings, however, there are a lot of variables.
While the Auto Stop/Start feature can save fuel, there are other negatives and I prefer not to deal with this feature and it is either turned off or disabled on my vehicles. I am not looking for 30 MPG out of a 6000 lb brick with a V8, if I wanted good fuel economy I would have purchased a very different vehicle.
juantavarez127
