NHTSA opens preliminary probe into more than 870,000 GM vehicles
solli5pack
So are the new motors considered to fail at a higher rate than then older 07 and up motors failed? And is the repair process as straightforward/DIY friendly as the older motors as well? Understood that failed bearings is a complete tear down but failed lifters isnt so bad.Currently shopping for a late model Tahoe to replace my 08 Yukon (which had a lifter fail at 110k). Maybe I can find a nice deal on a fixable truck with a motor knock?!
B-train
Ya know, one has to wonder if a NHTSA mandated recall wouldn’t actually **benefit** gm, as opposed to class action lawsuits.. because for one if i understand correctly, if a recall is in effect then lawsuits of that subject cannot proceed in court, correct? Then also, I’m sure gm will try the obligatory C.Y.A. & minimize the numbers of failures and issues.
And could gm truly foot the bill for that many defective engines.. or will have another case of government motors bailout.
Not to get off topic, but what exactly are you referring to that could cause the ground strap to lose continuity ?
Agreed on the convenience of the timing for lawsuits.
As for the being able to afford it: do you know how many engines and labor can be produced and paid for with just 1 of the billions in yearly profit GM makes? I hope this holds their ass to the fire to make it right considering how much they 'value' their products with the ridiculous purchase prices they demand.
I don't know what y'all think this is going to do. GM is already reacting to the problem and trying to fix it. Losing money and angering your customers is not a good way to do business. Hopefully they'll ditch their DIE hires soon and the poor decisions that lead to these failures will get resolved quickly.
mountie
My ( sold) '88 GMC C2500, had a few warranty concerns.
I later learned about the TSB..... I learned to be SURE you put in writing the EXACT USE OF WORDS required to repair the problem.
As per the Technical Service Bulletin is written !! Or your mafia GM area representative may deny.
Scarey
I get it.. oil pressure is low.. you are going to loose bearings further from the pump. My 2024 yukon has 1100 miles on it.. 5.3. I noticed on the first change.. a lot of metal material in the drain oil. I then took the filter apart to see.. what was in there. There is a lot on the filter.. what you see on the magnet is just a pass over a little bit. I wonder if they are doing something less in the engine build. Maybe just quality down to where the engines do not last? I can say.. it is a lot more metal than what my 2.7 had.. not really happy,at this point.
I think it is a good idea to dump the oil after a month or so.. when new.
If that was a reciprocating airplane engine, it would be a mandatory tear down.
PPK_
Oklahoma City
I am more a power plant guy… usually we watch material in the oil.. and listen with vibration analysis tools on units and gearboxes… and you routinely measure.. so you have a pattern of wear.
Anyway… when you see bits of metal.. it is not good. Where is it coming from? The rockers? The crank? Lifters? Are clearances good enough we are not having problems?
Anyway.. i know gm is building 5k motors a day. They know they problems too.. i think quality is not where it was when i had a 2018 5.3.
blanchard7684
Senior Member
Somewhat off topic, you'd be shocked to see what shows up in the first oil change for any Toyota in the last decade plus. Both a previous 2018 Camry and brand new Grand Highlander we have now were absolutely full of metal when I dumped the oil early. Pretty much every model you'll find that observation (and panic) for those that DIY the first couple of oil changes. It doesn't take long for the components to wear into each other and they're fine for 200K miles on nothing but oil, filters and plugs.
Can confirm.
Tundra, Highlander, and 5 different 5th gen 4Runners… all had large chunks in canister housing.
UsualSuspect
SoCal
it’s a preliminary investigation, they will ask GM exactly how many engines were produced, how many at each facility (I think there are 4), who were the parts manufacturers\suppliers, maintenance records, and how many have failed out of the 870,000.
For those looking at other manufacturers, this chart shows the number of investigations opened by NHTSA over the last 12 months. GM is denoted by the purple 2.
MH48
So, YES the GM trucks look awesome and are loaded with lots of goodies and some good technology. But why do we keep throwing more and more big money at the 5.3/6.2 DOD/DFM not-so-good technology? Oh the cost of our toys!!! And yes we put up with a lot of failures just to ride in sweet style.
So Why not keep our money in the bank for two/three years and send OUR message to GM? Incidentally, I own a 2002 Avalanche with 130k , original spark plugs, wires, coils, o2 sensors, cats, radiator, rotors, calipers, etc etc etc. And also, all original AC components, and, cold as ice in Florida summers.
And yes, I would like a ‘24/‘25 but not at the expense of the ride and the failure prone so-called technology.
That’s my own personal message, my own small voice.
Hopefully one day GM will act in good faith and not go the route of failure.
Have a Terrific 2025!
jfoj
Seems from info I am finding is the front main bearing and the #1 and #2 rod bearings tend to be the more common failure on the 6.2l engines. This is most likely due to the front main bearing and rod bearings #1 and #2 being the last in the oil flow path or being furthest from the oil pump.
So yes, oversize lifter bores could be a contributing problem because the cam and lifters are supplied oil first and the front lower portion of the engine could be oil starved, or what about the 0W20 engine oil being a contributing factor as well? Could also be due to oil consumption and running the engines low on oil as well?
trojan24man
