Mitchsmith67
I made a call with my blue tooth when I hung up my radio was producing no sound when I go to the phone part of the my link it shows the call still active and on hold. I push end call and sound comes back for 5-10 mins then mutes again. I reset it to factory settings I turned it off opened the door and turned it back on I entered into on star mode and nothing seems to work has anyone had this happen or does anyone have any suggestions?
often the "fix" for technical glitches is to disconnect the battery for a couple minutes, this resets things kind of like rebooting a computer.
if the problem continues to occur then it's possible you may need a software update that the dealer could do (for a fee) or if you have the ability to update it yourself.
if a software update does not resolve it then you need to look at other options such as a in-depth diagnostic or module replacement, etc.
mcguire7
