2013 Chevy Suburban LT heated steering wheel upgrade
petethepug
Michael
SoCal
* Must have 07-14 full size SUV or 07-13 full size pick up with steering wheel heat element embedded option.
* Purchase OEM clockspring with equipped for heated SW option. Aftermarket Dorman clockspring known to have issues.
* Review posts on the install procedure and where to pull a single power lead to it. Approx 07/08 used an in line fuse from the fuse box and approx 09 used a dedicated lead from the fuse box marked for steering wheel heater.
FatBob
you need the steering wheel with heat option and a clock spring that matches it, then you just need to run a power wire to the clockspring from a accessory power source.
the clock spring sends the power to the steering wheel you just need to connect the power to the clock spring connector.
you want accessory power so that you don't ever even accidentally leave the steering heat button on and drain the battery.
you can find the bcm power pin outs with the gm upfitter guide which is free online
You are correct.
I will add you need to also run a ground wire.
From experience with a 2011 Silverado, be sure to use an accessory 12 volt source. The battery will still drain, even if the switch for the heated wheel is not left ON. I had to rewire mine from a hot at all times to an accessory switch 12 volt source. No idea why the battery drained, but the heated wheel was not turned on.
buckwild27
You are correct.
With the stuff i have it plugs into the factory port for the heated wheel
zaahirkhan49
