j91z28d1
That's the first time I've personally used a plug, had my dad and many friends have to use them, but it was always on ATVs or side by sides out in the desert.
So it was usually a really big puncture that took multiple plugs and just slowed the leak enough to get back to camp and park it for the trip if they didn't have a spare.
I could barely even get the reaming tool in the hole that the screw made because the tool is so much larger and the steel belts are very tough obviously.
But I'm happy that I was able to get it done and it actually sealed up perfectly. It's holding no problem so that was a bit of a surprise to me especially with using only one and on my first attempt. Lol
These days, most plugs are self-vulcanizing meaning the seal very well in street tires. back in the day they weren't.
they can be hard to get in, I try not to ream to much and damage cords any farther. so they can definitely be harder to get in. especially if you have the ones with just a screw driver type handle. the t handle ones you can use both hands on help a lot.
I've got tires at work so thick you gotta use a drill to open up the hole enough to get a plug in. these are non DOT tires only rated for 30 mph max and we only have a car tire level tire machine. you can get them on a rim when new using lots of tire lube, but until they are worn down to the cords, they aren't coming off. if plugs didn't work, I'd just throw the whole thing rim and tire in the dumpster.
You could always cut the tire to get it off the rim.
89Suburban
Bull in the china shop
SE PA
I definitely had to do that with my ATV tires that were on there for 15 years lol
Cut into pieces trying not to hit the rim, the rubber bead still refuse to let go of the steel.
I DO NOT MISS messing around with breaking down the beads on ATV tires!!!!
DodDel5-3-6L80e
I dedicated a lot of time to some mods on my Tahoe this weekend. I replaced my low beam halogen lights with one of HID Guy's kits, plasti dipped my chrome surround on my grille, tried to repaint my front bowtie (FAIL!), replaced my interior lights with LEDs, installed my holster under my steering column, and replaced a seatbelt latch on the driver's seat. Now I'm waiting on my rear door actuators to come in as well as the billet bowties I ordered. As soon as they get here I'll get to installing them too. Long weekend but I got it done. What did you do to your Tahoe/Yukon?
I drove 120miles to the desert, 4 wheeled all over the place, and drove it home with no issues at all.
j91z28d1
you really can't. you'd need a torch and make huge mess. they go on narrow steel. tires cost 3 times much as the wheels. we just toss them.
plugs work great as long as you don't burn up your milwaukee drill trying to get a hole thru an inch or rubber for the plug lol.
Geoffsfas10
St. Louis
take a look at the dip stick tube also where it goes in on the right side, it has a o-ring and believe the crank position sensor has a o-ring as well, sort of behind the starter.
its wet on both sides of the block. My fleet mechanic looked at it today, he's a GM guy, and he thinks the pan gasket is where i should start.
I did go to install my rear door speakers. what a pain in the ass that turned into. First the back side part of the door panel where the cable release snaps in, the bottom part just snapped off so hopefully my door cable stays attached. then it turns out water had gotten on the speaker terminals, which caused corrosion and that's what shorted the speaker. and the new one doesnt work because of the corrosion. I had to stop there for the day, so i get to take it back apart, and guess im going to hard wire the speaker in now instead of the quick connector since its junk.
briwesric
