Best oil filters to help with oil pressure?
thefrey
2013 Yukon 6.2L 199k miles. Recently new to me - installed a new oil pressure switch and changed the oil
I have noticed low(er) oil pressures - maybe within spec but would prefer to be higher. About 15psi idle and 25 crusing hot. I installed a Fram Ultimate filter and have seen that sometimes different filters will affect your oil pressures.
Does anyone have any recommendations for oil filters that will help with oil pressure?
Foggy
KS
None will HELP with oil pressure.. That's a mechanical situation ...
I use the wix oil filters on my 14 6.2L
57060 or 57045 using the XP line is up to you.
Make sure you are using correct 5w30 Full Synth Oil
j91z28d1
did you have low pressure before working on it?
that's supposed to be a good filter you have in there.
Zjewell
