2015-2017 vs 2018-2020
FooglePhish
Ogden, Utah
I just bought a 2015, and am looking for parts. Many pages groups 2015-2020 all together, but some parts, on some pages, list the parts for 2018-2020, and says it will not fit my 2015.
The specific part i'm looking for right now are the roof rails for a luggage rack, my PPV has none. But i have seen the same thing on other pages, specifically looking for a replacement passenger side seatbelt.
So are they different, or are the pages listings incorrect?
Go to GMPartsDirect.com, enter your VIN, go to the Body section, and look for the exploded diagram of the roof area. You should find what you are looking for along with the correct part number. And, the cost will be significantly cheaper than the local dealer.
F
FooglePhish
Ogden, Utah
That page is great, and i'm sure it will be a ton of help in the future, but i could not find the rails i needed there.. just the cross rails, which are pointless without the main rails..
But thank you.
I think i found the part i need, but the page says it wont fit a 2015. I just need to know it that is true, or if the page is wrong and it will fit.
https://www.autopartsexpress.net/oem-parts/gm-driver-side-luggage-carrier-rail-84601089
another page with the item for a 2018-2020. Says it wont fit a 2015
https://www.gmpartsgiant.com/parts/gm-rail-asm-lugg-carr-si-84601089.html?vin=1GNSK3KC6FR687010&make=Light Truck&model=Tahoe / Yukon / Escalade - 06 Bodystyle (4WD / AWD)&year=2015&submodel=&extra1=&extra2=&filter=()
EDIT: Through other searches on google i was able to find it on that page, thank you.
TahoeInterceptor
