2003 tahoe heater core, evaporator, blend doors, actuators
ncalvo
FL
I am looking to pull my dashboard to replace the heater core and evaporator and want to replace anything else that makes sense while I am in there..
I have cj2 code, dual zone auto digital climate controls up front
I'll be replacing the dryer/accumulator, orifice tube since the ac system will be opened up
how many actuators there, which ones can you only access with the dash out?
I know I want to replace the mode actuator under the dash driver side because it has made a squeaking noise for years
I am looking at these parts lists and just trying to identify how many of each part there is
There are 4 actuators up front and you should be able to access them all without putting the dash in the service position when replacing the heater core. However, you can easily get at the passenger side temperature actuator and the fresh air actuator while making that repair. Use GM OE parts so you won't have to replace them again.
ncalvo
ncalvo
FL
thanks for the help
I did install a cabin air filter in my air box
scouring the forum i seemed to find a post with a lot of helpful info i will put in this thread below
if i'm not mistaken it requires
3 of these (GM 15-72971, 89018365) https://www.rockauto.com/en/moreinfo.php?pk=452286&cc=1412244&pt=10721&jsn=705
1 of these (GM 15-73952, 89018374) https://www.rockauto.com/en/moreinfo.php?pk=1309340&cc=1412244&pt=10721&jsn=700
There are four main actuators located in the dash:
1. Mode controller
2. Fresh Air/ Recirculation
3. Driver blend door
4. Passenger blend door
The actuators may generally be found in the following areas:
1. Mode - Driver side footwell (right side of steering column). The actuator is mounted vertically and will have a plastic positioning track plate attached to it.
2. Fresh Air/ Recirculation - Passenger side upper dash (right side behind glove box). Mounted vertically. Will require disassembly of the dash itself.
3. Driver blend door - Passenger side footwell underside of dash (left side along center dash column). Mounted horizontally.
4. Passenger blend door - Passenger side upper dash (left side behind glove box). Mounted horizontally. Will require disassembly of the dash itself.
Here's some links that were extremely helpful in locating some of these actuators:
Fresh air/recirculation
http://www.sparkys-answers.com/2010/08/changing-recirculation-fresh-air-door.html
http://www.sparkys-answers.com/2011/03/2004-chevrolet-silverado-changing.html
http://chevroletforum.com/forum/sil...ature-valve-actuator-replacement-22624/page2/
Driver blend door
http://www.sparkys-answers.com/2009/09/2004-chevrolet-tahoe-blows-hot-air.html
http://chevroletforum.com/forum/sil...temperature-valve-actuator-replacement-22624/
Warrior0977
