Knock when cold
Denalibro76
Good morning all you fine folks. I have a 2009 Yukon with the L9H and correct me if I’m wrong but it doesn’t have AFM right? Reason for my post is I have a knock when the engine is cold. Not really noticeable at idle (except initial startup) more noticeable while driving until the engine gets to about half normal operating temp. Not sure if it’s piston slap or rod knock? Since I haven’t experienced either issue before I thought I’d ask you what is more likely?
I've had a similar knock since I purchased my new-to-me 2007 Yukon XL Denali, and it goes away as the motor warms up. I attribute it to piston slap, since I've replaced all of the lifters and installed new exhaust manifolds with ARP bolts.
I just baby the motor, until it is fully warmed up.
rdezs
If you upload a video with audio..... Piston slap should be 100% confirmed by many of us hearing it. Interpretation of sounds without actually hearing it is very objective. Like the difference between a slap and a knock.
As for timing of the sound, a rod knocking tends to get louder as the engine warms up and the oil gets thinner. Also louder with RPM increases and usually a pretty good oil pressure drop.
While the "official" position on piston slap is that it's harmless..... And this is just my personal opinion that doesn't coincide with the official position from GM..... Is that as a former machinist in years gone by..... Two pieces of metal smacking each other audibly is not good. I view it as a defect in the Piston skirt design, or the lack thereof. Common Sense tells me that if you slap an aluminum piston hundreds of thousands of times against something to where you can hear it, you will begin losing material. Now who knows, this might take 200,000 miles. And that is probably why GM says not to worry about it.
Sorry, a bit off topic, and in the form it's probably been beat to death like a piston slapping a cylinder :)
Denalibro76
Denalibro76
Piston slap, but usually that goes away in 30-60 seconds (when cold months around here, but really depends on ambient temperature).
Definitely is not rod knock if it goes away.
Could also be broken exhaust manifold bolt(s) which is super common.
Yeah. On cold startups it definitely goes away after a minute or so. I’m going to have to take the fender liners out and have a real good look at the exhaust manifolds to check for issues as I have heard what sounds like an exhaust leak when I’ve started it.
Marky Dissod
... 2009 Yukon with the L9H and correct me if I’m wrong but it doesn’t have AFM right?
Reason for my post is I have a knock when the engine is cold. Not really noticeable at idle (except initial startup),
L9H is free of any and all Engine Half@$$ hardware or software bullschidt.
Cap'n Obvious says:
Engine'll likely last longer and age more gracefully if you don't move out of park for a min after starting it,
and drive as gently as reasonably possible for the next five or six min.
Cap'n Obvious might not know that, if you choose the right motor oil and oil filter,
it might actually help minimize piston slap over and above driving gently til it warms up.
Blackcar
Have 02 Yukon that has piston slap since new. Tried to get warranted when new no go.
I have tried different weights of oil and the one that works best (least noise and quickest slap stop) is 5-W30 semi synthetic.
rdezs
Is this because it's an aluminum block?
My understanding is GM addressed the problem by coatng the pistons and lengthening the skirt. Lol, not sure if GM would admit that though.... Because that would be admitting there was in fact a problem
toxic Tahoe 4x4
