Wire harness under rear bumper for tail light
Mege
Newbie here, my tail light harness and the sub harness under rear bumper melted together. I’ve ordered new tail lights but can someone point me in the right direction for the harness under the rear bumper that’s behind the spare tire? It’s a 2016 Yukon. Thanks!
Welcome to the Forum from NH.
Pics of the truck, please.
Go to GMPartsDirect.com, enter your VIN, go to the Body section, and look for the exploded diagram of rear electrical harness. You should find what you are looking for along with the correct part number. And, the cost will be significantly cheaper than the local dealer.
M
Mege
Thanks for the response!
Here is the picture of the harness I’m looking for. I can only find the tail light wire harness that fits directly into the back of the oem led tail light on gmparts. I need the harness that is in the picture that goes up behind the spare tire. I can’t find that on the website.
The first 2 pictures are of the wire I need. It plugs into the tail light harness and it goes up behind the spare tire.
The 3rd and 4th pictures are of the actual tail light wire which I’ll be ordering as well.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
What's the last 8 of your vin#
M
Mege
That harness is part of the chassis harness, but you can get the mating connector to repair it.
GM#84743891
$89.99
Thanks so much! I hope there’s a YouTube video for replacing it
M
Mege
GM#84743891
$89.99
Appreciate that. I’ve found it, but since it’s not a replacement harness, is it somewhat easy to repair it? For a non professional
Buy the pigtail and splice the wires if you aren't comfortable with re-pinning the connector. Rock Auto graphic below, but it also should be available from local brick and mortar stores.
dellguy3700
