Brought a new (to me) Burb home
Loki223
Loki223
Elk, WA
Interesting....haptic motor failure or wiring issue is supposed to set an alert which isn't appearing for me...but PN is 84017512 if only for my own future reference. I'll track dwon the correct PN for the heated seat and then probably order some cushions and debate about leather or not. Mine is in pretty good condition. One thing i've noticed is there appears to be a difference in the heated seat function for those with AC seats and those without. So i'll dive down that rabbit hole at some point i'm sure
Loki223
Loki223
Elk, WA
I think the heated seat element for seats with ventilated seats is 13520660, but wokring on verifying it. the haptic motors can be found on amazon for fast and cheap, and being that i don't have an error message, i wonder if the left side one is loose in there or something, so i'm leaning towards new seat cushions for the front from the seat shop, and a new heating element for the driver's seat bottom while reusing the stock covers since they are in good shape, but i'm going to inspect them closer before ordering things
Loki223
Loki223
Elk, WA
I'll keep talking with myself. heard back from a dealer while i was driving, 2 revisions on the seat heater with ventilation, and no notes even with the VIN to decide which one is the correct one.
LH mat with the 1.5 inch neck is part #23170194
LH mat with the 1 inch neck is part #23223774
Decided to wing it and go with 1.5" inch neck, i'll see if that was a good decision or not. And since i was ordering that, i decided eff it, and ordered new seat bottoms for both driver and passenger, and if i'm going through all the effort of swapping the foam, i might as well slide new leather on there too rather then reuse the old stuff. So i pulled the trigger on that last night, should have soem freshly comfy seats next weekend for the Suburban. Thankfully i'm taking the wife somewhere nice for thanksgiving, so maybe she'll let me just tinker in the garage on Saturday? Ordered the durafoam from the seat shop via amazon, along with new leather from them. Took a while to find it on their amazon store, but buying it there let me save 5% and use some amazon points i had racked up to drop down my out of pocket price. I'm just hoping the mat i ordered will work for me, if not i have a feeling the seat is going to be sitting out and the suburban will get to spend some time in the garage waiting for a replacement
tuckerrnr1
Port St Lucie, Florida
Following to see if that is the right heater element. Even in Florida, the heated seat is nice on the way home from work to ease back pain.
Loki223
Loki223
Elk, WA
I think either one should work.... 2nd design is 23223774, first design is 23170194. 2nd design has a 1" long "neck height" 1st design is 1.5" But there are no notes or specs on which one is correct, and which one fits what, even by vin. It's tear down, and inspect I ordered the 2nd design so i guess i will find out. and compare when i pull the seat apart
Loki223
Loki223
Elk, WA
But from all the pictures and info i've found, they use the same electrical connections. My guess is the neck height is the piece that goes through the seat bottom and connects to the cooling fan...
CMoore711
The vibrating sensor in the driver seat of my old ‘15 Yukon Denali went out and it was a known issue.
It would beep and alert with red lights on the HUD, but no vibration. It was a known seat sensor issue. And that was before 40K miles to the CPO warranty picked it up at the time.
Loki223
Loki223
Elk, WA
Does it just have one motor/cibrator on the right side of the seat? or two, one on each side of the seat like newer GM rigs?
CMoore711
Honestly I don’t know. The repair was done under warranty at the time so I never searched part #’s or got into the details.
Sorry man…
Loki223
Loki223
Elk, WA
Sorry man…
On your wife's esky, it should be the same seat basically. Do you know if that vibrates both sides or just one side of the seat? from what i've read there should be a warning on the dash if there is an issue with the system, and i don't have said warning. but i suppose i'll find out when i tear down the seat hopefully next weekend. our 4 wheeler is going to take priority, since it decided to no longer like it's stator, and it has a job while the burb is a spare rig that i like to spend money on because i have an addiction to modifying vehicles....
TerrynHouston
