Thanks. Finally did a deep dive with my mechanic on the new beast yesterday. It's in about the same shape as the 1500 'Burb was when I got it. Leaking radiator, needs all fluids changed out, and new shocks and bump stops. That's really about it. Good news is I still have the other aluminum radiator I had repaired in hopes of selling it after it let go and Cold Case sent me a replacement under warranty for the 1500. So it's going in early on even though it's just a bit of weeping in the plastic side. Previous owner had a Tru-Cool transmission cooler installed so I don't even have to worry about that - other than doing a better job of mounting it when we switch radiators. Bilstein 5100s all around and repair the passenger side torsion key where some jack-leg tightened it on a diagonal instead of keeping it vertical. Have no idea how the hell you do that.
Other odds n ends like a broken drivers side door pull where someone trying to get in the car pushed down on it too hard but basically it's in good shape. Need to get the passenger air bag replaced and see how badly the stealership screws up the dashboard. May be doing another Dashskin after that, plus a door panel. Switching the onboard air compressor over from the 1500 and then I'll sell it.
Nice truck! Looks like those are probably 285/70R17s (33s) on the H2 wheels, so you've got a mild lift too. At minimum cranked front torsion keys but it looks similar to mine that I've lifted about 2" front and rear and still had to do some trimming and front fender liner reshaping to not rub.
You nailed that on the head. I wondered if those were H2 wheels. The tires are 6 year old K0-2s, so slicker than bat shit in the rain but I'm going to try to nurse them through until the first of the year. That white looks good, too.
