Blind spot not working
2018_Yukon
Macomb county Michigan
Hello! Last week I had a “service side detection system” notification pop up and the blind spot monitors have since stopped working, I did get under the rear of the yukon and didn’t see dirt on the side detection modules or any issues with the harnesses (I cleaned them just in case). I’ve also noticed that lane keep assist does not work during the day anymore but only at night. I checked the front windshield camera and noticed that the black housing the camera sits in is crooked and about 2 inches off the windshield (got my windshield replaced about a month ago) .Could the blind spot not working and issues with LKA possibly be because of the crooked front camera and it not being fully on the windshield?
Big Mama
Virginia
There may be other problems in play but I’d start with going back to the glass shop. Do you have access to a scan tool to look for codes?
ReaperHWK
The front camera is independent of the blind spot module. Front camera does the lane keeping and blind spot monitors do blind spot detection and cross path detection when backing up. The only common module they both talk to is the haptic seat. If that’s broken it could shut down both.
A agree need to scan the modules to see what code it’s throwing.
you might try looking at the harness connector on those claymores and see if there is any corrosion or signs of water intrusion and check the fuse box as well.
Big Mama
Virginia
Try the scanner you have just to see. It may be something to consider buying a bidirectional scanner. I don’t think the ones the parts stores use go that deep either. @ReaperHWK point is a good one. Does your seat haptic work?
2018_Yukon
2018_Yukon
Welp coincidentally , got in and put in drive this morning and a service park assist notif has popped up and the parking sensors are not working. I did click the seat alert option though and didn’t feel anything buzz.
check the harness in back for that as well, some have been known to come lose from the bracket under the vehicle, some have shorted and melted the wiring, can be a big hassle
Big Mama
Virginia
And you may want to check your battery and cables. Hang in there. You’ll figure it out. @Doubeleive calls our trucks rolling computers so poor connections and low voltage can cause problems that seem unrelated.
Tgwest
