Aluminum / XFE NNBS Front Suspension Rebuild
992dr
Eastern N.C.
@petethepug Man I'm not sure if this has been covered.
Do the hubs from the 07/14 fit the newer aluminum hubs?
I'm ordering new ones now but put it on hold until it is confirmed they fit the newer aluminum XFE spindles.
Thanks
petethepug
petethepug
Michael
SoCal
We narrowed down the terminology to hubs and knuckles. In which case all the hub assemblies on our 1/2 ton SUV are cast iron steel. The hubs are the assemblies with the studs anchored into them.
The knuckles are either aluminum or cast iron. Both versions bolt on to the cast iron steel hubs.
The difference between the alum & iron knucks is the holes where the LCA mount to them. Alum knucks have a larger diameter hole for a the larger ball joint that the Alum LCA have.
Yup, the aluminum and cast iron LCA both have different sized ball joints but, both the alum & cast iron UCA have the same size ball joints.
992dr
Eastern N.C.
I get so confused with some of this terminology haha. And I always forget that it doesn't have spindles.
So, a Timken wheel bearing hub assembly for an 07/14 will bolt to the newer style aluminum knuckles?
petethepug
petethepug
Michael
SoCal
Correct.
Pretty sure the alum hub has a larger diameter tapered hole because it needs more material to have the same strength as the smaller iron hubs mount hole.
Oh yea, the tie rod end mount hole on the alum knuck is a different size too. It needs a 15-20 specific tie rod end from GM’s electric rack.
petethepug
petethepug
Michael
SoCal
Ordered a new OEM radiator, coolant reservoir and two new front hubs. Pretty sure the petcock on the OEM radiator is the source of the leak but at almost 190k on a likely OEM radiator, it’s due.
Found an interesting article on my preferred mfg for bearings, SKF. Turns out GM got together with them to create a better hub assembly for the 06-09 STS-V. They installed 6 lug hubs on a 4 door passenger car for a few years.
The technology bled over to the Escalade and is now known as a hybrid hub. Apparently it’s now used on the Escalade-V. No better time to replace them then when the front end is apart.
RockAuto has em for an unbelievable $139.79 ea.
91RS
GA
The factory radiator does not. If you have one, it’s an aftermarket radiator.
992dr
Eastern N.C.
Just ordered my hubs :)
j91z28d1
interesting
BLACKTahoe2016
