2008 TAHOE METAL FUEL RETURN LINE
FJA1791
Hello,
I am new to forum and not new to owning my 2008 Tahoe. My fuel lines are rusty and return line is currently not available. I already purchased an OEM metal hard feed line and would like to replace both lines the same. Does anyone know of an aftermarket company that makes metal hard lines? OE line part # is 15946264. I see aftermarket companies that make metal hard lines for previous model but not for 07-14 models. Thank you for your help.
Frank
Forum Tip - Free TIP Friday
If you're going to tag someone be sure to start the tag with the "@" symbol, then start typing the member's name and pick it from the dropdown list that appears. Otherwise your target might not see it.
You should see this since you started thread, but the only way @915_Tahoe sees it for sure is that I tagged him here.
F
FJA1791
Thank you @Fless.
MikeDawg223
