Installing "2021 PPV" style 6-Piston Brembo Front Brakes on a 2007 Yukon Denali
MrMonte
4 piston brembo's in the rear you say? I was looking into doing that but I ran into alignment issues with the calipers I have. So you have pictures of yours?
Haven't installed yet but this is the adapter I purchased.
k_arnold72
Oh okay, gotcha. I personally like the crescent moon look that the front brakes have, so I was trying to use camaro 4 piston front calipers as my rear brakes. Guess I was reaching to much. Rotor diameter is within a tenth of an inch, though, so it seemed like it was doable.
I'll look into that adapter and see if it helps my dilemma, thank you
Willied1981
I just wanted to update this info. I just installed gmc Brembos,on a 2013 Yukon Denali. I have the factory 20 inch Denali and they clear and bolt right up.
petethepug
Michael
SoCal
Awesomeness. Great way to tell the Mrs. your safety upgrade was a huge value add instead of replacing those antiquated, anemic old rotors and pads.
You can tell her; now you’ll be able to safely stop this thing like a police car.
:shakehead:
seZ71
