New to me project 13 Yukon XL Denali
thefrey
I’ve posted something similar in the intro page, but I figured it may be better suited in this side of the forum where I’ll be spending most of my time.
I’ve been lurking around here for the past couple weeks so I figured I should do some in depth info about the Yukon. Here’s the Yukon:
2013 Yukon XL Denali AWD with the 6.2. Metallic black paint. I picked it up in January with 197k miles for 4k but oh boy she needed (and still needs) lots of TLC as she was very neglected. I feel like it was a good deal but I’ve also opened a massive can of worms with it. It’s in decent shape for a 12 year old car in my opinion considering its past and the interior is in pretty good shape. Countless trips to the junkyard have helped me fix lots of cosmetic issues and made it much more functional
Here’s some before / after photos of the interior detail. They didn’t use any floormats so a deep clean with an extractor (and covering them with weather mats) did wonders
Other things I’ve done so far is:
- Install, rewire & repaint 3rd brake light/rear spoiler (didn’t have one)
- Rewire headlight clip
- Install gas struts for rear window
- Install new rear window button
- fixed broken rear window defroster tab
- Re-installed random missing trim pieces in cab
- New license plate, brake, parking, headlight and other bulbs
- Took off passenger side running board. They were the automatic ones and one of them was broken off and the passenger side was stuck down
- New tires
- Fixed rear windshield wiper
- Oil pressure switch
- Fixed broken windshield washer lines
- Programmed 2 new key fobs. Didn’t come with any
Things I need to do:
- fix oil cooler line leak
- fix 3 of 4 door handles (broken or missing)
- possibly engine mounts (infamous clunk)
- chase flickering lights
- chase valve train tick
- fix some rust and body damage
- new rims as the OEM chrome is peeling / leaking
Overall, yes it is a decent project, and outside of oil changes and changing brakes I do not have a crazy amount of experience working with cars, but I enjoy it and am very comfortable turning a wrench and working with my hands and I’m not afraid to do something I haven’t done before. This will be a great learning experience for me in the end and I hope to get the Yukon to 275k miles at least.
Here’s a picture of the rust and the body damage. It’s not the most sightly thing but it’s not very noticeable from afar. I’ve always wanted to learn how to do body work and paint so I figured it would be a solid learning opportunity
Rockers are still in good shape which is good.
Thank you everyone already for the advice I have received and thank you for any future input, I hope to be able to give back as much as I can
petethepug
Michael
SoCal
Is this brown carpet in a tan carpeted truck?
Oh wait, I figured it out. It’s wet just before scrubbing it so it looks darker :)
petethepug
Michael
SoCal
Haha, mine was worse. I actually switched to brown carpet because the interior was brown.
thefrey
thefrey
I just saw your edit haha. The funny thing is that it was dry in this photo. The only thing I had put on there was dawn dish soap and you can see the streaks. But other than that it was dry
Immediately once I got it wet, the water coming off it was brown. Looked like somebody had spilled a soda all over the floor immediately
thefrey
thefrey
What machine/soap did you use to clean the carpet?
Not sure if I’d recommend this but it did work ‍lol
I took dawn and sprinkled it all over the carpets and then put oxy clean powder over the carpets. In the bucket I had warm water (probably should do cold but it was 14° when I did this) and the bucket had a carpet cleaning solution in it
I got the carpet wet with solo cup from the bucket and then used a brush attachment to get some agitation and lather going (making it wet enough and lather/soapy is important) and really worked everything in with the brush. and then I borrowed my parents Hoover pet carpet cleaner and it has a wand. So I used that as an extractor and it worked well
Airman68
Kaukauna, WI
Looks like it did a nice job. I have a seat... someone... spilled coffee on and need to be cleaned.
amesbury34
