2025 new tahoe/suburban feature wishlist
StephenPT
St. Helens, OR
I would like more storage for larger things - i.e. I’d like to carry a Milwaukee M12 inflator for flat tires, inflating sports balls, inner-tubes, etc. If they made the fuse service panel twice as wide on the driver side, there’s plenty of dead space back there that’s not being utilized.
PPV_2018
Senior Member
U.S.A.
Yes, I've seen that posted in another thread. We are saying that it should be a setting in the vehicle that you can disable. You shouldn't have to add a wire harness to disable auto start.
This is definitely one thing i love about the PPV’s:: autostop disabled from the factory.
Sgt1411
I would like the Connected Camera feature that was marked before production to be active on all 2025 Tahoe/Yukon/and Escalades to actually be functioning. This idea "its coming in a future software update" is getting old. I normally install a DashCam but didn't buy one as they clearly stated the PVR feature of the Surround Vision System was better.
nomech
Senior Member
What does this mean from the owner's perspective? You'd be able to connect to the vehicle to download the camera footage from the front camera?
Sgt1411
The system acts as a 360 Surround Camera DVR/PVR like Tesla does. It will record all cameras and then you store them on an SD card thats located in the drivers rear 1/4 next to the fuse block. In my manual it says if I connect a USB to the console port I get PVR functionality but its apparently not available yet.
The connected camera feature is this:
nomech
Senior Member
There is a camera inside? I didn't know that.
Sgt1411
Well thats another issue, there is supposed to be one in the overhead console but mine isn't there, its in a few 25 Escalades I have seen but no Tahoe's so far. Possibly an option not available for Tahoe at first production like Super Cruise. I'm trying to determine if I can retrofit as the wiring is likely there.
navyseal334
navyseal334
I wonder if this "update" will end up like the post-covid commitment/promise of adding chips to vehicles that shipped without features activated (heated seats); my assumption is hardly anyone had chips installed and eventually stopped expecting them.
Hopefully this update doesn't end up as another perennial "it's coming" promise.
OffBrandCornDog
