Fuel pump return
Hpb99
Hpb99
Florida
" He said fuel companies change from winter blend to summer blend & it tends do strip the lubrication from the pumps causing them to go out & i havent been putting a pint of oil in the tank lately.."
Where do people come up with this stuff?
What is a squirter set up??
What I call a squirrer setup is a throttle body with 1 injector ,its what we call them around here.. as for the oil in the gas , makes sense ,anything the friggen gov can do to give the public the shaft they will, look at how they did with diesel fuel ( low sulfer) signs were posted on pumps ,not for use in vehicles before 2007 . Didnt have the lubrication for the motors ,so guys were putting a qt of trans fluid in the tank to roll. & Ethynol is alcohol & will strip lube off ) out of bearing .
Eman85
If you have a throttle body it would have 2 injectors and isn't what was used in 99.
People used to put clothespins on their fuel line too and used creek water in the radiator because they thought it didn't freeze.
Hpb99
Hpb99
Florida
Guess you never quit eating lead paint or licking windows either . Actually let just drop this , i dont care what you think or believe ,i have better things to do & im sure you need to get back to your game of hide & go f yourself... Lets just ignore each other & move on.
PV90274
