Shut down /electrical gremlins update
John H Daniel
I posted about a mysterious full power off. Also had a few gremlins; one high beam didn't work; left turn signal intermittent.
Replaced the switch and checked/cleaned ground and power cables. Lights were still weird. I could wiggle the wire bundle from front bumper area and get the hi-beams on.
I removed and disassembled the big fuse block (thanks again Youtube!) Think I found it; plenty of possible opens/shorts due to moisture and corrosion. Cleaned it all and everything seems to be fine.
petethepug
Michael
SoCal
Ironically, it looks like an overhead shot of a cemetery showing all the tombstones and mausoleums.
New sheriff in town is gonna clear all that riffraff out past the state line.
:grd:
John H Daniel
John H Daniel
:grd:
LOL, it does! Now I can't unsee it...
Used a lot of contact cleaner and gentle brushing; worried about damaging the green coating.
Ibustbravo
Centennial, Co
Ohh.. I have the same problem which at appeared shortly after I replaced the engine. Interesting, it did sit out a winter and some rainy days while I had it apart.
BGNuke
