… door locks gone crazy
ya easy enough to swap out the switch with a used one, I bought one for the wife's suburban it wasn't that much maybe $35-40 off of ebay
PPV_2018
PPV_2018
Senior Member
U.S.A.
But it’s $14 on rockauto for GM genuine ???? Or is this the wrong part?
PPV_2018
PPV_2018
Senior Member
U.S.A.
if that's all you want to replace or try, I bought the whole switch on ebay complete
do you have a pic? there’s no other listing on rockauto and i’m not seeing anything that looks like a complete assembly on eBay
mikez71
Nice that you have a separate switch. Integrated on the 07-14's.
You could always remove yours first to test.
If it looks right, and it's listed for your vehicle, it does look like a simple (cheap) part.
PPV_2018
PPV_2018
Senior Member
U.S.A.
@PPV_2018 Have you put a bi-directional scan tool on this yet?
Negative. I don’t have access to a bi-directional. I only have an old autel i use for checking cel’s but i never even bothered to hook it up on the ‘hoe . . .
I meant to the exact switch you found, i already used similar search query and came up with the same results, nothing looks different. I see plenty window switch assemblies that are full and complete, but not what I’m looking for. Is your wife’s burb a k2? If not maybe the switch assembly changed . . .
Frick it, i just ordered one. For basically $20 why not, we’re still on the cheap end of the parts cannon. When it comes in I will replace with the new one, see what happens . . .
Yep k2, I think I'm confusing windows switch with door lock switch, I rarely drive hers and my Silverado automatically unlocks when I shut it off so I barely if ever use the door lock switch or I just pull the handle twice
teamleatherjacket
