01 daily/project
05Single
afraid of the dark
She looking fly!!! Ptm handles and esky vents and you're done with the outside.
This is more my style
sent from the last frontier
05Single
afraid of the dark
I plan on getting the same tails soon too. Just simple and clean. How stock should've came instead of that ugly amber with the weird bulging
I still like my candy tails more that most aftermarket tails out there.
Spencer_waynee
Spencer_waynee
I'm thinking about going to esky handles. I like a little chrome just not too much all I want to paint math is the bumper cap, rear appliqués, and the handles
Spencer_waynee
Spencer_waynee
I'm stuck. I'm ready to throw this damn intake in the garbage. Fair warning this will be a lengthy rant. I've had this mother******g intake on and off several times. The latest realizing I have the wrong adapter. Finally I said screw it gonna just order the $250 harness and be done with it BUT THATD BE TOO EASY! My Tahoe is an 01 which is usually dbc but since it has traction control (assuming) is why it's dbw and has the extra plug. So that fast adapter is the ONLY adapter I've found that looks like the back side of my throttle body/gasket. It's for a fast 102 mm which I doubt will work idk what the mm opening is on the nnbs intakes. If I order the x-link I'll still be screwed bc the throttle body that was on the intake only has one plug. I'm starting to question if this is worth 10-15 hp but at this point I'm $150+ into it...
05Single
afraid of the dark
I'm starting to get scared to do mine. I have to get the tbss tb tho, probably make it a little easier. Idk it's last on my mod list. Maybe never get to it
Sent from my SAMSUNG-SM-G900A using Tapatalk
Spencer_waynee
Spencer_waynee
Picked up a set of mcgauphys drop spindles for $100. Went ahead and got them and the ball joints done tonight.
The ride improvement is great over the lowered keys, no more bouncing around. I ended up ordering the speed engineering long tubes and y-pipe. Really hoping not to have fitment issues like others, but we will see. After this Ima gonna take it easy and start doing more of the little things. I really need to get the ugly frame painted and a little maintenance stuff done.
Get the spindles new or used? I should've bought a set! Hopefully you won't have the same issues I have with my y pipe.
CT_85
