01 Tahoe Rear End Whine
Bedore
Greetings all,
I noticed while taking an extended trip last weekend occasionally I will hear a whine that may be coming from the rear end. It's mostly when I am coasting, and seems to go away when I step on the throttle. Is this something from the rear end?
Splatmaster527
Cleveland, OH
I along with many others have a whining noise too but mine is coming from the front end...It goes away when I turn left and stays if not gets louder when I turn right...
Im thinking wheel bearings going bad...
maybe you are having the same problem
zaathur
my 02 has done it the entire time i have owned it when i give mine gas around 60mpg on, it will have a slight whine then when i let off the sound goes away
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
whao you get 60mpg?:) Try a rear diff service. I noticed that on mine too, But i had 2nd row folded forward, and 3rd row Removed. I dont hear it so much with everything in place.
chevy_man
Great Falls
Are any of you AWD? There was a TSB for the AWD system for an internally balanced front driveline if the coasting whine was loud enough. My denali does it but 160K miles on a set of gears, they're probably a little sloppy!
zaathur
yeah more like 13mpg lol anyways i already flushed it twice with 2 different brands of synthetics still had the same noise
QUYHMK
