My Truck:
2001 Yukon XL 2x4, 5.3L, 1500 SLT
Maintenance:
-Partial transmission fluid change. The drain plug was stipped and I couldnt get the linkage off in order to get the pan completely free. So the filter was NOT replaced.
-Oil change recent
-Battery is about 5 years old
-Spark plugs and wire changed [left me stranded on the road]
Mods: 17" Denali rims, K&N air filter
I need some advise here. I've got two issues:
1.) Transmission slips when I slow down at a stop light but then hit the gas, even gently. I'm really scared to drop serious dough for a tranny rebuild or purchase. Are there other things to check to help solve this slippage?
2.) Electrical draw down: when I first start the truck, it goes through this tantrum phase of rough [like a steady wave length] idle and drops in voltage along with drops in RPM. Lights also dim if they are on. This happens with load [radio and A/C running] or with out load. Bad ground? bad alternator?
Thanks in advance for any advice!
Maintenance:
-Oil change recent
