I recently purchased an 01 Yukon XL. The blower motor recently wouldn't turn off, even with the key off.
I pulled the fuse for the blower motor.
After researching, it led me to the blower motor resitor/control module. When I removed it, water poured out of it.
I then removed the blower motor housing cover. It was soaked with water. I removed the blower motor.
From what I can tell water is dripping off a black plastic lip at the top of the dash.
It's not the HVAC drain, it's not the heater core.
I removed wiper arms and cowl panel. There is zero debri in the cowl area. All body seams look to be good.
After pouring water on numerous locations, I have narrowed it down to the passenger side, below the windshield(meaning windshield seal is good).
I can't see any way the fresh air vent that protrudes through the cowl area can get water to leak there. Also, there are no wet spots in the area(even with pouring water).
I need to get this leak fixed soon. I do want to keep replacing blower resistor modules and it's cold now...lol.
I have read hundreds of post and have yet to see a solution. I wil add pics when I can. Any help would be greatly appreciated! Thank you!
