Josh Cushing
- Joined
- Jun 20, 2018
- Posts
- 3
- Reaction score
- 2
ok like the title states I’ve got an 02 Yukon XL 5.3 flex engine with a miss on startup:
Symptoms: rough idling,shaking. Crank the vehicle. Runs good for about 15 seconds, then starts to miss pretty rough. I can press the gas really high in rpms, problem goes away.
Things fixed so far:
Initially there was a P0300 code and a MAP sensor code.
With the snap on Zeus diagnostic machine, showed miss on 2,4,6,8
Found that compression was low on 4 and 6 due to spring retainers being worn. Replaced springs and retainers and compression went back to 180 on all cylinders.
Replaced ignition coils, plugs and wires.
Replaced MAP sensor- reads are at 1.42 at idle, 4.95 WOT
Replaced cylinder 2 fuel injector due to in being clogged
Cleaned all injectors with pressure cleaner
Replaced intake gasket
Replaced Cat converter on even side bank(was clogged) reaching 500 degrees, will ODD BAnk was at 300 degrees.
Replaced fuel filter(old one was good but, just for good measure)
Fuel Gauge shows proper fuel pressure. Pump is operating as it should.
I’m leaning toward either a faulty PCM or MAF
Advice would be awesome as I’m stumped.......
