02 Yukon Denali Ac issue.
Hammer02
Hammer02
So little update on the blend door actuator. I got a brand new one and plugged it in before installing it and when I turned the temp knob...it did nothing.
Side note I turned the blend door by hand to see if the air gets cooler...it didnt.
Hammer02
Hammer02
This is the clue that tells you exactly what it is.
"The wife and I noticed one day the ac got colder as I turned a corner a little fast and sharp. Weird right?"
Not weird, what happened is your blend door swung back to the correct spot with the inertia. Used to happen to my Tahoe. Most likely your blend door (plastic) is broken (split), happened to my rear blend door as well come to think of it. It will work fine and not depending on how the split door spine catches with the other part and may or may not move it.
Your choices are to rip the dash apart in order to separate the plenum (I think that is right name) to replace the door with another plastic one. Or you can use a heater treater mod which will install an aluminum single door that is controlled by the bottom module. Google heater treater .com
The good - it is fairly easy to install, eliminates the top blend module which is hard to get too and replacement door is made of metal so will last a long time.
The bad - you eliminate the dual zone ac to one zone (my wife forgets this and adjusts her side - placebo effect) also you will have to cut open the plenum and create an access door. So the drivers side actually controls the temp for both driver and passenger.
What blend door should I bee looking at? The one I checked it the lower main. But from what I understand there is more.
Also it's not dual zone...if that matters.
latvius
Ariton Alabama
The blend door right behind the center console. Not sure if the single zone has the actuator at the bottom of the plenum or the top. My guess would be the bottom
BTW You have 3 blend doors, one for the defrost direction, one for the fresh air and one for the temp of hot / cold.
This video is showing how to replace the blend door actuator (hot /cold), not sure if this is a single zone or not but gets you in the right location.
But to be clear the actuator is not the problem it's the blend door that the actuator moves is broken. You can't see it unless you open the plenum which would be a lot of work. Hence the heater treater mod that you cut the access panel into the plenum.
Hammer02
Hammer02
So I watched the heater treater video for the yukon and Im convinced that blend door isnt broke.With the acuator off I can turn the blend door and get really hot air to come out and back to get cool(not cold)air.So it seems the door is intact.
latvius
Ariton Alabama
hmmm weird, wonder why the temp changed on a hard turn? Is that actuator completely wrecked? Can you move it by hand? (Should'nt be able too).
Chris2144
Well from what you have said it seems your blend door is working since it gets hot when you turn it one way and then gets cool the other. So what I know from past experiences is if your compressor is failing generally there rear will be the first to experience problems then the front. Being that the front is worse I wouldn't suspect that but not rule it out just yet either. Plug the actuator in and adjust the temp to verify it's working you say you have already done it by hand and verified the temp does change. Check your fan clutch to make sure it is working and check the condenser fins to make sure there not clogged and it can cool properly. If no problems there then I would put a set of gauges on to get a better idea of what's going on. If the orfice tube for the front is partially clogged then it would cause this problem. For the rear if it is not blowing as cold as it should then that could point to the expansion valve being clogged. Most of the time this is caused by either metal particles from a failing compressor or gel substance from nasty freon.
Hammer02
Hammer02
So I've been so busy with the AC being fixed and a new problem that I forgot to give an update.
So...it was a leak. A leak that the last place I went to who "Tested for leaks" and then "filled" the coolant..said wasn't there.
New place caught the leak and repaired it and filled me up with the right amount of coolant.Cold as can be! My wife is an ac queen and I've never heard her say she's too cold...and now she does!
Thanks for the help guys!
