02 yukon denali xl need to replace air ride with gas shocks
johnnunez29
I been looking online but haven't found much. I need to replace shocks on my 02 Yukon denali xl I went to auto zone and asked for shocks they had gas shocks that were pretty cheap (I don't mind them not being high end). I just really need to know if they fit my truck? has anyone replaces air shocks with gas shocks? if so what did you use? can the auto zone shocks work? it said in their system "for truck without z55 autoride" please help. thanks
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I moved this from the tech section since the tech section is only for "Here is where you will find technical write ups on installs and how to's." and not for questions.
yes you can use those. Just disconnect your battery, pull RTD fuse, remove wires going to front shocks, and replace rear shocks. Then reconnect battery
J
johnnunez29
where did you move it too? also I already removed the rtd fuse a while ago.. since this things shocks have been blown for a while. can I put these shocks in all around? are they direct fit? and I need an alignment but my tires move sided to side when on jacks what can that be? thanks and sorry for the thousand questions lol
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Moved it to street suspension
Yes they can go all around
Yes they are a direct fit
No idea
J
johnnunez29
No idea
thanks did it yesterday all 4 were direct replacement. think I need to replace the rubber joints in the suspension. would you happen to know where I can get this cheap? thanks
