'02 Yukon XL Does OBDII report Transmission Temperature
Lew Schiller
Intrigued by the OBDII Bluetooth readers and Torque PRO. Mostly want transmission temp but the other features are very cool as well.
Will my '02 Yukon report Transmission temperature via OBDII?
Thanks!
Scottydoggs
NJ
my 05 does on the t app. as well as more things then you'll know what to do with.
engine running, add gauge, then you scroll through the pid list, anything highlighted green is working.
L
Lew Schiller
Sweet!
Do you have to go through that process every start-up or will it retain the settings?
afpj
Torque Pro retains the settings if you save it as a profile.
moosehead
05 yukon Denali.
Using the free torque app I can't get transmission temp or oil pressure.
Johnb21
Interesting...I have the Pro Torque app and the Transmission Temp #1 and #2 options don't light up green when truck is running. I wonder what I am doing wrong or might be different. I have a '05 as well. Thanks.
Scottydoggs
NJ
i also have torque scan installed because knock retard was not showing up for my other car. its a free add on, after that it worked, it also does some abs scanning like wheel speed for each.
BurbyRST
