03 Denali new on the scene
adventurenali92
Big Bear Lake, ca
OK any recomendable guys that may do this? Or is it easy enough that I could tackle it?
X3 on fixmygauges.com. They do excellent work! I had them program my Escalade cluster to the correct mileage on my truck and it’s perfect! If you’re comfortable with a soldering kit, you could resolder the contacts for the odometer screen. I’m not skilled enough with it to do the job. There’s a member here, @ScottyBoy that can do the stepper motors and gauge backlighting. I would think he’d be able to do the odometer screen as well since it’s basically them same thing. I sent my Eascalde cluster to him to have him do the led lighting and new stepper motors for the needles and he does a fantastic job! Still need pics of the truck too! Haha
F
Flexxicon
F
Flexxicon
Figured out how to post pics so I'll put more up at a shop getting rear diff cover swapped
live2pull
Phoenix, Az
Welcome to the forum, thats a great color. Denalis themselves will lead to higher maintenance cost compared to Tahoes and lower trim model Yukons simply due to AWD and more electronic features of the vehicle. For me, this added cost was worth it for the big motor, creature comforts, and stylish exterior.
Side bar; people have mentioned the water pump, curious on what people think of doing the timing set and oil pump at the same time. If indeed a pan gasket is needed and the water pump is leaking, wouldn't it be prudent to replacing the timing set and oil pump also. Aren't you already at the timing cover?
RickyBobby52
