03 hoe, 35s with keys
Jbird
Just put these on yesterday. Have cheap ebay keys and thats it. Toyo m/t 35s with rockstar 20s. Had to do a little trimming nothing major
Arctic-Rodz
RGV Texas
uff... stuffed! thats crazy. I have a 6" on mine and I had to do quite a bit of trimming to clear my 35's
Sickblutahoe
Montrose CO
Its weird to hear people say the had to trim with a six inch with 35s. Now keys with 35s is a different story. You should lift the rear it looks like you've got a load in the rear cause the fronts so much higher.
Arctic-Rodz
RGV Texas
Id depends on the offset of the wheel. Mine stick out about 2" from the fender.
Do your tires rub on the inner fender under suspension flex? i cant imagine it not rubbing at all with 35's.
and yea, that a little too much "cali" lean
brucebruce45
Your lift pushes the wheels out further as well. To the op, take some better pics
zaathur
looks good wish just my 33s wouldn't rub backing up because of my offset
chacho44
MOTORCITY
i just put 33's on stock 20's on mine, Nitto Mud Grapplers. Rear is good front rubs a bit, Might consider the cheap egay lift as well.
polobuds
East Bay, CA
i have 33" nitto trail grapplers on mine. front rubbed a little when in reverse. i trimmed the inner wheel liner and all is good. you try doin that already?
DenaliRob
