03 Tahoe factory speakers in front in and out...
Tahoebigdog03
What's up family I'm trying to get some help on what could cause my front speakers up front in the doors and tweeters to go out for for a few minutes then comes back on. ....The speakers and whole setup is factory so I'm wondering if it's the speakers or the HU. The system is Bose
Thanks for the help
617Yukon
Boston, Ma
Start simple, loose wiring? Factory amp maybe giving out? Does this happen under heavy volume, hitting bumps etc?
Tahoebigdog03
Tahoebigdog03
Seems to happen at high volume but then again seems to happen when I hit bumps also. This really has me confused. Oh just to note the rear speakers work fine in the rear doors and third row, they don't cut out at all.
Thanks
Novah
New Hampshire
Thanks
Did you ever figure this out? I have the same issue. Mine will cut out even on a smooth road.
Tahoebigdog03
Tahoebigdog03
Never got to the source of the problem yet I've just been dealing with it since I have been really busy..... I my just do a complete upgrade around Christmas.
Tahoebigdog03
Tahoebigdog03
UPDATE.......
I just installed a new pioneer DD and JBL door speakers and the two front door speakers and tweeters cut out and then come back on.....I thought by changing HU and speakers would've solved that problem.....You guy's think it's the AMP. I might just run new wire from the door speakers to the HU.....
Thanks
Tahoebigdog03
Tahoebigdog03
Problem solved.....bypassed bose amp with 1200 watt aftermarket amp, four 6.5 JBL door speakers and two 12" subs in the rear. Nice and clean
Harald1959
