03 Tahoe project
2003FatSo
2003FatSo
Sway bars and bump stops just came in. Waiting on front hubs and all this is going in. Majority in front. Bump stops and rear sway bar for the back. thinking 2" wheel spacers in the rear. Front track width will increase by 2" per side with spindles. They will only be for rear.
02Burgundybeast
South GA
I am running the same lift setup. I went with 1.75" rear spacers to even out the track width. the 2" Will push it past the front. I also went high end with my wheel spacers. I got them from another forum member that had them made for his truck. Don't trust the cheap ones. What sway bars did you go with? I am in the same process of replacing all the bushings as well.
2003FatSo
2003FatSo
How do you like the drive feel with the wider stance? Any vibrations from the spacers? Do you have any pics?
Bell tech sway bars with hardware and bushings.
02Burgundybeast
South GA
I will have to take some pictures. I may have some on photobucket that I can upload. I do notice that roads that have a very prevalent crown in them, the truck tends to wander back and forth. I am not 100% positive that it is related to the wider rear width because with the front spindles and rear spacers the difference is less than 1".
2003FatSo
2003FatSo
Switched out alternator this morning. We finished front end also. Put in 3" lift spindles, Bilstein 5100s, and belltech sway bars.
hoelift.jpg IMG_20161203_211508.jpg IMG_20161203_201145.jpg IMG_20161203_183545.jpg
2003FatSo
2003FatSo
Thanks.
I drove 250 miles without alignment on newish all terrain tires and rubbed bald. Smh. importance of an alignment
