Dantheman-2003
So I just re-geared my 03 Tahoe from 3:73 to 4:56. After 500 miles I changed my fluids. The front diff took about 1.5 quarts, which it called for 2. But I filled it as much as it would take.
The rear calls for 2.75 quarts, but I ended up putting all 3 quarts in. Stuck my pinking in there and didn't feel any fluid. Just wondering if all 3 quarts is too much. Any risks here?
Also after about 100 miles I noticed a drip. I didn't use an aftermarket gasket just Permatex. I didn't use lock tight on my bolts like some suggested, so I'll check that first. Otherwise I'll need to do it over.
Thanks!
Dan
Thanks!
Dan
