03 Yukon SLE - Which BOSE do I have (is it possible to check it using VIN)? :)
K
Konrad
Or RP4-GM11... :)
Wysłane z mojego MI 6 przy użyciu Tapatalka
Fless
Super Moderator
Elev 5,280
My '04 has the same Bose speakers and amp that you do, but not the same radio (I had a 6CD changer). It's not the higher level Bose (as @HiHoeSilver provided RPOs for that). Your amp and sub woofer should be in/under the center console.
Here's what I just installed in mine, and it works great. Crutchfield FTW. Keeps the steering wheel controls and the sub.
EDIT: your UB1 code is:
AM/FM STEREO, SEEK/SCAN. AUTO REV MUSIC SEARCH CASS, CD, AUTO TONE, DATA SYSTEM, CLOCK, ETR
K
Konrad
Thanks. I think, I'll order this RP5-GM11 :)
Unfortunately I can't buy this Crutchfield guide, as I'm not from the US. and it seems they don't send it through e-mail...
adriver
Or maybe there's a better solution?
Another question is why this new radio plays badly (the sound is very flat)?
Thanks
Did they use the factory speaker wiring? I thought those bose speakers are 8 ohms, and wired in series for a 4ohm load. If they just replaced the speakers into the original wiring, they could be wired to 2 ohm (most aftermarket speakers are 4 ohms). If this is it you could fix it by running new speaker wire. (~$10 in wire and a couple hours).
My other guess would be: Have you taken off the door panels to see what model the speakers are? They may be too high wattage to be connected directly to the head unit without an amp. (If the speakers are just too high wattage for the head unit, you would need to add an aftermarket amp, or get lower wattage speakers).
They could always be blown, but that's probably not it.
To get a better idea, would need to know the model of the head unit, and the speakers (so we can see there power ratings), and then know how they are wired.
IMO I would definitely try to get that aftermarket to work before I tried to go back to the Bose. At the very least, that head unit has many more features and options.
Fless
Super Moderator
Elev 5,280
It's online at Crutchfield.com.
K
Konrad
Thanks Guys
Crutchfield forces me to enter the U.S. address (I'm from Poland), and it seems they want to send this guide via dhl, etc.
I'll try the second company.
As for the installation in my car, right now there are new wires from door speakers (front + rear) to the radio (tweeters and sub are not connected). So the original wiring should be still there.
As far as I remember, only rear speakers have been replaced. I'll check what's there right now, but next week as I'm going on short vacations right now :)
Fless
Super Moderator
Elev 5,280
What "guide" are you wanting? The Crutchfield fit guide is all online. If you're looking for the installation instructions ("Master Sheet") PM me and I'll email you the PDF.
K
Konrad
What "guide" are wanting? The Crutchfield fit guide is all online. If you're looking for the installation instructions ("Master Sheet") PM me and I'll email you the PDF.
Yes, I meant those installation guides :)
Thnaks, I'll PM you.
K
Konrad
Hi. One more question. I want to buy this RP5-GM11, but there's also RP4-GM11. The difference is the OnStar retention. Will this RP5 work if I don't have OnStar (I believe I don't have is, but I'm not 100% sure :) )?
Thanks
CoyotesRUS
