04 Denali Headlight Inspection and cleaning
Finally going to do this... ordering later today. Any reason not to proceed with something like this?
No, if the brackets fit your headlights then it’s the easiest retrofit ever. No regrets.
This is a low beam only, pretty sure
The acme supers H1 is a low and high beam.
Also you can put whatever his system you want, doesn’t have to be acme.
But yes this will fit
I didn’t realize Acme sold a low-beam only H1. It seems that wouldn’t be desirable by anybody. Might as well have a shutter.
05Single
afraid of the dark
I stand corrected , says right there it’s a bi-xenon. I haven’t shopped them in awhile. I know at some point the standard was just a low beam pattern. So never mind these do have a high/low function built in. make sure as soon as you get them plug in the high beam solenoid and test the shutter functions at least 50x before installing
MechanicMike
Manitoba, Canada
What do you mean by "new bowls"?
I have an 02 Yukon Denali. I just started researching my headlight problem and I'm not familiar with some of these terms. I didn't know that these headlights could be opened up and repaired.
I'm trying to figure out what to do with my lights. I'm wondering if the chrome reflector is peeling inside.
My dims suck and my brights are no help.
S
Sdp1234
Southeastern PA
The chrome reflector is what I’m referring to as the bowls It was peeling badly in mine. I’m going to replace the complete projector assembly. I have everything to do it but just haven’t had time. I’ll send you full pics when I get to it.
This video may help
This video may help
The Morimoto Mini H1’s have amazing output, you’ll be super happy. The adapter plates make it a super easy job, normally you have to bake open a headlight assembly in order to do a true retrofit like this. This way everything just screws in from the back. And you can buy the pigtails already assembled from TRS so you don’t need to do any soldering. I did this exact same thing to some new Anzo U-Bar projectors for my 02 Denali, came out super nice. I did a write-up over at GMFS.com that got very little attention which I don’t understand but then those guys are all pretty much di*ks.
https://www.gmfullsize.com/threads/retrofits-in-the-new-anzo-u-bar-headlights.319939/
05Single
afraid of the dark
All true including the part mentioning the guys on gmfs being idiots :rotflmao:.
Also the fact that the brackets line the projector up exactly horizontally, where normally without the brackets you have to put the headlight on the truck then align the light rotation output and hope when you take it off to secure that position it doesn’t mess up the alignment.
Fredrikswe
