04 escalade traction control comes on when driven
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I only think speed sensor because with TC off, it doesn't matter if one tire is slipping/spinning or not, because TC is off. well if it's a bad speed sensor, it could make it "think" one wheel is slipping/spinning and activating TC
Yukon Lover
Maine
Makes sense, like I said it's worth looking into, but I would think it would do it randomly not only upon takeoff. That's why I thought maybe the pedal sensor was sending wrong info.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
could be. OP really needs to take it somewhere with a Tech2 or something that can hook up live and tell him why it's happening. Only 100% way to tell
M
Mbz03
Nathan I will changed both and Jody I might changed that one too if I hit the brakes the pedals kinda slides and then stops weird
---------- Post added at 06:32 AM ---------- Previous post was at 06:28 AM ----------
I just bought the truck and I'm fixing it little things and that's one of them thanks guys for the help it's nice when u can ask questions and get real answers and not smart ass ones I appreciate it
Yukon Lover
Maine
Welcome, that's what we are here for man. Ya fix the little things before they cause bigger issues or sitting beside the road. I don't have mine anymore but even with all the little issues they have I miss it everyday.
M
Mbz03
So guys a changed the speed sensor and still doing the same thing
hoss08
My 04 Escalade was doing the same thing, mine ended up being a wheel speed sensor. Its pretty much a guessing game on which one being mine wasn't throwing any code. I replaced both fronts (Don't remember if the rears have wheel speed sensors) and it solved my problem. A shop with a good scanner should be able to pinpoint which sensor is causing the issue. It could also be an issue with the wiring harness to one of the sensors as well since you said replacing one didn't help, a wire could have gotten pinched somewhere down the line. I'd definatley have a tech hook it up to a scanner and do a little live monitoring, they should be able to track it down pretty quick.
M
Mbz03
Thanks Matt
---------- Post added at 10:08 PM ---------- Previous post was at 10:06 PM ----------
The thing is if I shut the traction control off truck works awesome takes off great if I turn it back on at take off has lost of power till it hits 10mph and then it takes off
jfrief
