04 Yukon no power to instrument cluster/brake lights after engine swap
67Chevelle
I just finished swapping in a fresh 5.3 into my wife's 2004 Yukon. Every harness, connector and ground has been checked. All grounds were marked, polished and checked for continuity. Every single thing works perfectly except only the CEL and backlights come on in the instrument cluster (no display either) and the brake lights don't come on when the pedal is pressed. The turn signals and running lights work fine. The fuses have been checked, swapped and there is power through the circuits in the fuse box when there is supposed to be. I know these clusters can fail from loose solder but it's odd it would fail after an engine swap and the brake lights won't function either. I'll pull the cluster tomorrow and check for power in the harness. Other ideas?
Fless
Super Moderator
Elev 5,280
Here's the cluster pinout in a PDF if you don't have it handy. Good luck, and let us know what you find. Or don't find...
  • 2003-2006 Cluster Pinout.pdf
GunMonkey
