Kosherpotatoes
Hey all,
Looking for some advice. I have a few assumptions of what the title issue is but wanted some advice before diving in to this issue this time. So, in 2019 I bought my current 04 Yukon XL I replaced pretty much the entire front suspension with the exception of sway bar bushing. Uppers and lower control arm, tie rods, shocks, and wheel hubs to attempt to fix ABS issue (seems to have resolved it). So to get to the root of the issue. While turning left, it becomes near impossible at times. I don't know if it's wore u joints in the steering shafts or if it's the gear box. I guess it could also be a CV axel but wouldn't imagine the issue is only in one direction. Vehicle has 245k miles and previous things done to it are unknown. When I bought it I was a bit newer to GM family and wasn't sure what to look for. I don't plan to sell this thing anytime soon but want to get it back in good driving condition again. While I can drive it and just muscle through the steering issue my wife cant and I bought it for her. I plan to pull the upper steering shaft this afternoon after work and test both u joins for binding and excessive play. I'd like to avoid replacing the steering gear box but if it's the issue have no problem purchasing a new one. Any advice on how to go about the checklist from least expensive to most? I assume it's upper shaft then lower shaft, then CV axle, then gear box? Any other suggestions would be helpful.
