05 Tahoe w/ Bose Wiring Diagram & Other questions
mlutton
Redondo Beach, CA
All right. I know you guys probably see this a million times but I have been unable after numerous searches to locate a wiring diagram for the 05 Tahoe. I have found 05 suburban and prior year tahoe wiring info. Is it the same between years or models?
I have talked to an installer that thought that it is possible to wire up the Rear DVD (OEM) to an FM transmitter to get it to play over the new HU I am putting in (Pioneer 3300BT). Has anyone done this? If so could you give me some info?
Power supply- Do I need to run a better power and ground to handle the HU and the axxess steering wheel control or is the stock sufficient?
I'm sure I will have some more questions as I do the install but for now this is it. Thanks in advance for any help.
M
mlutton
Redondo Beach, CA
Thanks. That's what I thought but before I started I wanted to make sure I had my research done so I can finish it in one day.
Thanks for the reply.
Jliberatore
Could you email me the wiring diagram for the rear seat entertainment system. I need to know which wires that I need to splice into to make a video output cable
I want to duplicate the video from the rear monitor and have it also play on the front monitor
Please help
My email is [email protected]
stormtrooper777
