Hey, I see you have had these on a while. Have you had any issues with the heat of the LED pods melting at the plastic near it without having a heat shield installed. I was thinking about doing similar to what you have done here but am worried about the 200+ degree temp some led lights can get up to.
Also did you use the stock wiring that was used for the original fog lamps?
Thanks a ton.
Thanks a ton.
