Chevynut08
i have a 2005 yukon slt with autoride. One day it decided not to start but only crank. i beat on the fuel tank in hopes to rattle the pump but no success. the truck sat for a couple days before i could get it towed. when i showed up to meet the tow truck it fired right up like nothing happened.
it happened again a couple weeks later at my work. i figured i probly cant fix it if its not broken so i kept driving it. That time at work i pulled off the intake tube from the throttle body and sprayed a little starting fluid just to see if it would fire and it did for a second. So then i beat on the tank again while someone cranked it and it started but i dont know if it was just a coincidense or not. the truck sat for about 12 hours while i was working that day. i didnt specifically check the spark plugs nor the fuel supply. but it drives perfectly fine when it runs.
it wouldn't start for a 3rd time just before christmas and had it towed home. the battery died from trying to start it plus being so cold. i just charged it up this past sunday and it started right up. seems like after it sits for a little it starts right up. i haven't really checked anything yet, as i'm not sure where to start. Thank you sooo much for any advice!
