05 Z71 Lift advice
Ryno20
Looking to run 285/65 r17. Need lift, & tires. Going with XD Rockstars wheels. Like the Nitto Trail Grapplers, but they are a little more than I am wanting to spend. Any advice would be appreciated!
h8nbmps
You can run that tire with no lift i believe.some on here have pics to prove it.
I have 275/60/20 RBPs with a zero offset!!!
I rub on the front at full lock but it's minimal
Now my 285/70/17s on I had no trouble at all...
I have an 04 YD with air ride.
with my set up now my fender heights Driver side is 36" front and rear and my Pass side is 37" idk y my ***** off but I'm fixing to remove the airride and lift it 2".
Hope this helps any
Wouldn't let me attach more than 1 here's the 285/70/17 Hercules trail diggers on factory Denali 17s
Smokehouse
Hope this helps any
Will a leveling kit up front keep you from rubbing with your 20x9's?
If I crank my keys it probably clear my 33s "275/60r20" big thing with my wheels are a 0 offset. The factory is like +31 offset. Most after markets range +10 to +18 and clear no prob from past experience.
Edit: Another thing is my Yukon has the Denali package and rides lower than other Tahoes and Yukons even with my 33s idk why that is? But that might have something to do with it
You can also throw your wheels and tires on the front and if it rubs a bit like mine crank the keys a bit.
I plan on doing keys and spacers in couple weeks and putting z71 springs in the rear with bilstein 5100s all around and getting ride of the airride. That's why I haven't cranked my keys yet (2 alignments vs 1)!
conquer1
