good luck.
"putting down" the power being the important part here's an idea of mods and where mine was at stop where you want really, or dont
kidding, you're on the right track - mine went from a 15.2 stock/tune only to 14.1 with cam, (first) stall, headers/ypipe, and pretty safe tune.
slowly worked my way down to 13.6s over the next couple of months - different tuner, adjustable rear shocks, e-85 fairly cheaply.
at that point nothing seemed to help- i swapped to 4.10 gears, built on the headers/ypipe with 4" all the way back with magnaflow straight thru mufflers, coils overs in the front, starting tuning myself with hptuners, spohn rear adjustable bars, big open cone intake, nitto 420s
all that and it picked up a tenth, consistantly lol.
made the decision to swap out the converter, circle d told me when i bought the first one it'll do good to about 5-550hp i think the weight effected it quite a bit as well. first day out not changing anything and it dropped a few tenths 13.2-.3s with 1.8 60's. a little more tuning and managed to eek out a 12.99. it's been left that way for a few months now, i made a few little changes i didnt think would do much but last week at track it did a couple 13.10s and a 13.06 on 93oct
throughout all that it really hasnt picked up much mph, id have to go back and look at the earlier slips but it seemed to trap 100mph back then and still only does like 104 on a good day.
06 - you're going to be on a 4l60? what gears?
2wd/4wd? letting all the weight transfer and just running a good tire/shock would be rough on the rear axle but would cut a nice 60'
cams - to put down 450ish wheel hp even with a 6.0 is going to need to be pretty big, ie- its going to want stall and gears. if i only planned on ever doing a cam I would do a larger one than i have now (218/228) which is already larger than most of the "truck cams". .600+ lift will help keep the bottom end from feeling so sluggish.
