I am in the process of attempting my first Projector HID retro to my headlights. It has been done before and there are some vendors online that can do it, but they want way too much IMO to do a retro that I am pretty sure I can do by myself. So I am attempting to do this, but it will take some time as I don't have a lot of free time, and also doing research throughout the whole process. So this is going to be a while before I complete the project. Attached are some pictures of headlights for the Yukon that has already been done with the retro, the first one is from BlackFlameCustom that I happen to run across on the net. His setup is using the Morimoto Minis
This other setup is from a guy who responded to my thread over on the HID forum, and he has the TL projector in his headlights.
This is what I have done so far as of tonight. I purchased the R headlight on ebay for a whopping $20 shipped , was too scared to mess with the stock as I wasn't sure how easy it was to open. Turns out to be a piece of cake really. I got a heat gun and set it on high, work one section of the headlight at a time (this sucker is huge). To whoever say that the glue used is harder to remove, it was a piece of cake, took me a little less than 15 minutes to fully remove the two piece. Started first with removing 2 screws from behind the headlight, then heated 3 tabs at a time and popped them up once they got flexible being careful not to break it. I would use a larger flat pry piece rather than a screw driver as it is too small. put the pry in the crack and turned clockwise or counter, once you feel it opening move to another spot. Work your way around the whole headlight heating up one section at a time, it is really easy to open.
That is all I have so far, right now just doing some measurements so I can figure out which is the best projector to get. Any feedback will be read and appreciated, as I will be learning and doing it at the same time.
