07-14 Tahoe/Yukon Cargo shade & Cargo mat
St. Louis
They're wider and roll out further.
Now there are 2 different models for tahoe/yukon. One for power liftgate and one for no power liftgate.
CaptainAmerica1
Arlington TX
This one is long enough but the tabs in the rear aren’t right. Too narrow and kinda offset to the drivers side… So this must be for power lift gate.
kbuskill
NE. FL.
I have the short Yukon with no power lift gate.
Did you try flipping it over?
The reason I ask is because they can be installed upside down. The power liftgate motor is on the driverside so the offset should be toward the passenger side.
CaptainAmerica1
Arlington TX
FYI I’m not knocking the OP for this. It’s absolutely my fault for not checking fitment earlier. I’m just trying to figure out where it does fit and offer it to someone who can use it.
kbuskill
NE. FL.
I did..that’s how I came to the conclusion that it must be for a power lift gate version.
I figured as much but thought I would ask.
I found out that they can be installed upside down one time when I went to install it and it didn't line up properly with the powered liftgate side of my Burb.
Dflo92
