07 Burbn - Rear tires rubbing
B
bodymccannx
Thanks for the replies guys. From what I gather, this is fairly common then; I'm just surprised it does it with a mild 3" rear drop - if I do decide to go the full 4 in the rear, I'll have to expect even more rubbing and cutting!?
I would like to get the front to 3" (truck sits level now, but I prefer a slight rake), but have been unable to disassemble the struts - the top nut just will not budge. SoCal - Why not go with the springsl?
Re - the suggestion of using helper bags in the rear, pretty sure I can't while still using the Autoride shocks. Just a thought - if I switch out the Autorides for Bilsteins, would that result in a stiffer ride - I notice that the Autorides are a little "bouncy" at times.
Sweet_N_Low
Hmm, I would think the autoride would compensate for the weight addition, NO????
yates ™
Resident Apple hater
Iowa
I didn't think about the auto ride. I would think it would compensate for the ride difference. Maybe the auto ride is not set right after your drop???
B
bodymccannx
I don't understand why the Autoride would not be set right - I installed the new links as per Belltech instructions - I believe at 3in..
SPIS
