07 Denali amp & sub install
ThaHooch
Installed a JL10w6v2 sub with a JL XD600/1 amp...
I don't go into much detail, but if you need a better explanation or pictures...just let me know.
Tapped into the signal going to the factory Bose sub...this is located right under the cup holders. I ran the speaker wire to a Stinger LOC that I mounted under the plastic cover under one of the second row seats. Found out later that my amp didn't need a LOC...
4 gauge power connected before the main fuse...
Brought the power cable through the passenger side floor
Got the 12v remote from the sixth pin (zip tie pointing to it) on the orange "block" this is located on the driver side above the parking brake...
Amp installed...this thing is tiny
Some pictures of the ported box...
Bass control knob...I had to jerry rig the knob, because it is such a tight fit between the cup holders and the storage box, but I made it work.
I'll have to address some dimming issues, and the speaker box carpet could have been matched a little better, but overall, I'm very happy with it :)
stevek
Dallas, TX
Looks good! Why'd you pick to put the knob there instead of by your right knee or in the ash tray?
T
ThaHooch
Thanks! I picked that spot, because it's within easy reach, and if I ever want to return it to stock, I could just order a new cup holder insert. I thought about the ashtray, but I usually have my ipod in it. Also, I don't think I could have fit it in there anyways, because I needed about an inch of clearance on the back side of the knob.
Jonnyfamous
Houston, TX
Nice setup man. I bought my hoe about 3 years ago and just out that the person who had it before me did the same thing.
Jbird
how is the sound quality being tapped in on the stock sub? what convertor did you use?
T
ThaHooch
It took you three years to find a 10" sub in your truck? :think:
I think it sounds great. I used this stinger:
http://www.stingerelectronics.com/productDetails.aspx?ProductId=109&CategoryID=3
The retail on their site says $51.99, but you can find one for around $15.
basshertz
so cal
that an awesome clean build i have a couple of questions am about to install a system also into an sierra with bose are the speaker wires from the bose system also located under the cup holder tray in that truck too it seems to have the center console just like urs ? am not a noob to the car audio game just with this whole LOC and finding the amp remote turn on lead on the stock wires of the car
and the amp turn that u tapped into the pin is it sending power from ignition or only when the radio is on ?
---------- Post added at 03:23 PM ---------- Previous post was at 03:22 PM ----------
here u go this is where i buy all my audio http://www.sonicelectronix.com/item_17012_Stinger-SGN13.html
sparky 843
