ny_summit
- Joined
- Feb 20, 2023
- Posts
- 43
- Reaction score
- 26
Going to be replace the oil pan gasket as it's leaking, and the pick up tube o-ring. Should I go OEM gasket and o-ring? Is there a better aftermarket choice?
I've also read that vehicles without dod/afm can plug the pressure relief valve. Should I plug it? I want to make sure I get what needs to be done at the same time. Thank you!
